2012 Chevy Cruze A6 1LT RS
Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
If you exceed the axis of a graph it uses the last value it saw.
on my logs, it doesnt matter because we never get past that much airflow anyway... i adjusted the bypass valve numbers, both of them... much better response.
ok cool story! threads dead!
its not dead. people are busy and progressive developments take a long time especially when your going one table at a time with as many as there are available to you guys now.
EX: The LNF came out in 2008 mid year and i still make minor finds here and there. The major finds didnt really get finished solid till maybe 3 years after support was released which was late 2008.
now factor in delays for price restricted dyno time, cops, limited track event dates, non-live efi tuning ....... it will be a while
This thread usually pick up on the weekends.
2007 Chevy Trailblazer SS AWD with boltons GP tuned
2012 Chevy Cruze A6 LTZ RS Vermount Stade 0 tuned
Like I mentioned, I have ZERO time to do anything in my life. Wife works until 8:30 at night and I'm watching my son until then. The weather has been pure ass too, nothing but rain. Figures, weather is clear but my parents are coming from out of state to visit this weekend. Never ending cycle
well last year with my new ported head i spent an entire week strapped to a mustang dyno doing steady state testing and fixing camshafts and dals to optimize power usage through the entire load range. i never unstrapped it, just poured gas into it and made sure the fans were cycling air properly. since i know the price of my bill wich was even at a discounted price i do not see people spending anything near the time i spent lol. it hurt really bad paying that bill...thats all ill say.
well i feel good about what i have now. and i have a sonic rs manual 1.4l turbo im gonna be testing and tuning.
I may have some time today as long as the weather holds to try seeing what effect playing with the cam timing has. Also strongly considering using the 2013 cam tables too and seeing how the car runs.
Yeahhh.....don't use the 2013 cam tables. It didn't sound good when going WOT and my car also went in to the low octane timing table for some reason(once again getting a lot of knock around 2000rpm just cruising), might be part of why it didn't sound good too. I may still mess around with it as the non-wot driving felt smoother.
In regards to the knock around 2000rpm. I keep seeing this every time I flash a tune, it's as if the car is just running way too lean right there and once the fuel trims kick in, the issue goes away.
You guys think this is a good indicator of the turbo's compressor map? I can't seem to get Garrett to give me the info
Looking at an old log, I'm hitting 1074 lb/hr @ 232kpa. That's roughly...what...2.32 pressure ratio? I'm not good with this stuff Looks like 225-230kpa is the sweet spot for efficiency if this table is to be believed as fact.
Wow...if you want to stay out of the hospital for whiplash, do NOT set your Pressure Delta Factor table to 4 across the board. Boost ramps up fast when going WOT and then I hit some crazy ass limiter that makes the car jerk back and forth like crazy. Holy shit.
Were you scanning when this happend?
See attached You'll see how the boost ramped up really fast and then you'll see as I go to full WOT the car goes bonkers
That did not look like fun. I won't try that. Looks like you are using the 2013 Stoich AFR.
