Results 1 to 8 of 8
Thread: speedometer ?
    May 2004
    Gaithersburg Md
    15
    speedometer ?
    I am a new user of HPTuner, just got it a couple of days ago.
    I compared several of the Tuner edit frames with those of LS!edit and have found some small differences on values read out of the pcm,
    The real strange one is the speedometer frame,
    on LS!edit it shows current gear and tire size of 3.42 and 26.1,
    on the Tuner frame the previous (cu rrent?) tire size is blank and the gear ratio shows a dim 15.98..
    This makes me a little nervous would like some help /reassure ance about this,,,
    Thanks.
    Sep 2002
    Chicago, IL
    6,395
    Re: speedometer ?
    Can you please send us your binary so we can look at it.
    We got this guy Not Sure, ...
    May 2004
    Gaithersburg Md
    15
    Re: speedometer ?
    Binary sent..............
    Thanks for the reponse,
    May 2004
    Orlando, FL
    8
    Re: speedometer ?
    Keith I am seeing odd behavior as well on my 98 F-body. LS1-edit shows
    Gear 3.23
    Tire 25.63
    VSS (PPM) 52358
    VSS (PPR) 10240
    VCM Editor shows
    Previous TH - blank
    Previous GR - blank
    Engine (PPM) 52358
    Trans Scalar 4.0
    Speed Input Pulses Per Mile 7812
    You should receive a .zip (ls1_edit.zip) of the VCM .bin
    Tim
    Sep 2002
    Chicago, IL
    6,395
    Re: speedometer ?
    98GreenC5, I checked your binary and it is ok.
    If you make gear changes enter 3.42 and 26.1 as the previous (Saved) values and then enter the new values in the right side boxes to make the changes, then click save changes to commit.
    The values below are what is calculated when you click save changes. They are the actual values the PCM uses to determine actual MPH for both the engine and transmission.
    May 2004
    Gaithersburg Md
    15
    Re: speedometer ?I think there is still something
    Keith,
    Don't you guys ever sleep?
    I tried your suggestion to put old tire size (26.1)in previous and it entered ok.
    If I try to enter anything in previous gear ratio , it is not allowed.
    (no message just no entry- the grey 15.98 stays)
    when I enter 26.1 /3.42 as new tire size/ gear ratio,
    the values below change...
    if I'm not changing anything why do these values change?
    Something is not right with the 15.98 in the previous box.
    I'm glad to know that the values are right in the VCM,,but
    I'm glad I don't have to change tire size or gear ratio because
    I would not have any faith that it would be right..
    Richard
    Re: speedometer ?
    we are working to enhance this functionality in future releases.
    For 98's the way to modify the values is to calulate the scaling factor by:
    factor = (new gear/old gear) x (old tire/new tire)
    note: increasing gear increases the factor, whereas increasing tire decreases the factor.
    then multiply both the PPM (for cluster calibration) and Trans Scalar (for trans speed calibration) by this factor. Enter them manually.
    although, i would bet that your Trans Scalar is not modified from what it was as stock.
    I count sheep in hex...
    May 2004
    Gaithersburg Md
    15
    Re: speedometer ?
    OK ,i looked at my stock file and the values are:
    engineppm 15514
    transscalar 4.000
    speed inp/mi 7812
    original 2.73 rear 275/40/18 tire.
    my modified file:
    engineppm 15852
    transscalar 4.000
    speedinp/mi 7812
    3.42 gear 295/35/18 tire.
    you are correct that scalar is same as stock
    I'll be happy with what I have until the enhancements
    in the future fix it so you don't have to be a math whiz
    to change tire/gear in the program.
    LS1 edit has these values in the tables for the 26.1/3.42
    VSS 15852 pulses/mi
    OSS 2990 pulses/rev
    if this is any help.
    looking forward to when everything works as expected...
    thanks for your time and effort.................
    Richard
