Results 1 to 6 of 6
Thread: Injector duty cycle PID???
    Apr 2004
    East Tennessee
    339
    For give the simple question :
    I used the forum search function and could not find it. Where do I find the injector duty cycle PID in the VCM Scanner???
    Thanks,
    2007 CTS-V LS2
    Nov 2002
    Central Florida
    2,503
    Re: Injector duty cycle PID???
    You may have to work with the injector pulse width
    and calculate it up (using RPM)?
    Apr 2004
    East Tennessee
    339
    Quote Originally Posted by jimmyblue
    OK, do u know what the formula is???
    2007 CTS-V LS2
    Nov 2002
    Central Florida
    2,503
    I believe it's
    PW(msec)*RPM/1200 = Duty Cycle (%).
    http://www.ecanfix.com/~mdhamilton/dutycycle1.html
    I got this info off a LS1Tech.com thread.
    Apr 2004
    East Tennessee
    339
    I believe it's
    Cool, thanks
    I did a little research and it looks like that is it.
    Now if I can find out why my 42lb injectors (48.5 at 58psi) are running at and over 100% duty cycle at WOT above 5800rpms???
    2007 CTS-V LS2
    Nov 2002
    Central Florida
    2,503
    One thing is to make sure that there is not a big
    round-off (round-up) error. With that fat of an
    injector you shouldn't need 100% unless you are
    a big-HP motor, probably boosted. Also I have a
    vague recollection of people mentioning that the
    PW may have some inaccuracy to it, as reported
    (generically) but I don't have anything specific there.
    It may also be possible that there is something about
    the commanded AFR, PE, the IFR and maybe other stuff
    that is telling it to max out; what does your O2 /
    wideband info tell you about whether 100% is over-
    rich, or falling short? I think the stock calibration data
    may be "fighting" fuel system shortcomings with
    kooky high PE-vs-RPM that might want to be peeled
    back for big injectors and solid plumbing.
