I'm having problems with afr command when i go into boost. There are two paramters that enable PE mode correct??? First one is TPS i have mine set to 20% at all rpm's and the second is map enable PE mode i set mine to 100kpa. Help if this is wrong to enable PE mode??? Because this is doing nothing for me. The only way to get into PE mode is at 100% TP. I'm i doing something wrong??? I'm on a mac give me a couple mins and i'll download tune.F-2 SD 3 bar tune.hpt3bar map pe enable Attachment 39702Attachment 39703mode2.hpl
