Results 1 to 5 of 5
Thread: l67 swap qusetion
    Dec 2005
    windsor, ontario, canada
    51
    l67 swap qusetion
    when doing a l67 swap into a car other than one with the l67 option, such as a cavalier is there a security or feul enable to code into the pcm? im running times in the 15.0-15.1 stock with the l67.The grand prixs run this stock and are 600lbs heavyer. So why an i slow? i have intense standard pcm for a 99 gtp. Also im using the 4t65e. my best 1/4 is 14.3@101mph. i have a scan with a 3.4 pully, ported tb, 104's, standard pcm, open exhaust 2.5" and cold air.
    96 l67 CAVALIER. PT76GTQ TURBO AND IC. PB: 10.62@138MPH ON 19PSI. DYNOED 502WHP AND 415FTLBS OF TORQUE.
    Apr 2005
    Allentown, PA
    8
    The first thing I would do is change the timing tables back to stock. That intense pcm is commanding to much timing for you. You were getting 7.7 degrees of kr The stock timing table will probably end up running more timing than you are now, which will give you some a little more power.
    1/4 mile times are all about the launch, GTPs can ussually hit 2.0s and 2.1 60 foot times on street tires. Your trap is decent, but being 600 pounds lighter, I would think you should be trapping a little higher.
    92 S10 3800 A4
    Dec 2005
    51
    my 60ft times are 2.2-2.3s.
    Mar 2008
    Waukesha, WI
    101
    It also looks like you're running out of injector. Inj DC is high 90's. What other mods does the motor run?
    Feb 2006
    Canada
    1,963
    I've been told that the injectors are good in those motors till 100% even higher by a bit. I'd say the timing table and your fuel trims will be key to getting your car in line right now.
    What is in place for torque reduction? Properly setting up the trans is very important too. If you search some of Russ K's posts you'll find trans tables for your set up. Compare them to what you have and see what you think.
    2000 Trans Am WS6
