I have a LE5 in a dune buggy (well 2 of them actually)
donor car is a 2006 G6 with a ECU from a 2007 HHR (E67 ECU)
we have removed vats, and a few DTC's that were not needed, and it runs pretty good overall,
HOWEVER...
once in a while like when grabbing 2nd gear and accelerating the gas pedal just quits working
just as if you unplugged it.. not "limp mode" it just plain doesn't work... dead..
if I reset the computer it comes back and works fine..
no DTC's show.. just no pedal at all.. idle only
as a test, we started the engine and unhooked the pedal, and then hooked it back up, it rendered the pedal useless until we cleared the codes (it threw p2122 and p2127)
the difference being when we unhooked it intentionally it DID throw a code, when it does it on it's own it does not throw a code.
both buggies have the same "tune" and both suffer the same problem
one important thing to note is we used a 6 wire coated trailer wire to run the APP wires to the front of the buggy (the ECU is in the rear of the buggy)
approximately 8 feet or so of this very high quality trailer wire is used on both buggies.
is it possible the resistance is all wrong running through this trailer wire and the ECU is shutting off the pedal?
thanks in advance
Hefe
