Bill Winters
Out of the LSx tuning game
OK so my buddy read somewhere that if your emissions tests aren't going to complete it won't let the case learn work. Sure enough I set all the DTC's to no error reported so the tests completed and it worked like a charm. Little tip from your uncle Bill. Credit to Terry VanCleve for finding this little tid bit.
Bill Winters
Does this apply to an E 40, 2 bar SD, that has P0102 and P0103 failed? If I set to no error reported, will it even start?
I don't have the 340 and 341 dtc's, but I have had some screwy things happen since I swapped in this motor about a year ago. Just thought I should cover all the bases.
Thanks,
2013 Silverado 5.3, 6L80k 8.8
You can still get the emissions tests to go to completed with the P0103 still set.
Bill Winters
crank relearn
my 6.0 motor now resides in an old truck, therr is no connection for the brake lights to the ECU, other thank the trigger for the TCC lockup.
will i need to wire a positive to the ECU for CASE to work?
Has anyone done a Crank Relearn with current version software on 2015+ Mustang?
Also has anyone ever gotten the error box Timed Out Access Denied while doing Crank Relearn?
Steve
