Results 1 to 20 of 37
Thread: E92 Vats delete for standalone harness/engine dyno applications
    28,272
    Pretty simple
    OS tab-set the two vats switches to disabled
    System tab-set starter diagnostics to disabled
    Write entire
    done.
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Nice Bill! This little tip will be handy when we lock ourselves in on the dyno!
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Dec 2008
    on the Dyno
    1,825
    Anxiously awaiting the first E92 equipped car to hit our rollers! It's exciting learning a new system! Keep up the great work fellas!
    Located in Central Kentucky
    ShorTuning
    Dec 2006
    Pensacola, FL
    489
    Is this the same procedure for the E38 ECM?
    Nov 2009
    All Around
    3,149
    ^E38 has the starter check under the OS tab and you must go to the DTC and disable 1631 code
    Dec 2006
    Pensacola, FL
    489
    Thanks Sultan. Do I have to apply the TCS patch also?
    Dec 2006
    Pensacola, FL
    489
    Got it fired up but it won't stay running very long. I'm pretty sure my injector data is off.....Here's the log.
    Dec 2006
    Pensacola, FL
    489
    I played with the injectors some more and finally got it to start and idle! One step forward, with many more to go. Here's the log of it idling.
    Dec 2006
    Pensacola, FL
    489
    And a instagram video:
    http://instagram.com/p/ghIL3jknuC/
    Oct 2013
    228
    looks like your upstream heaters come on and then the upstreams , especially b1s2 goes dead , stft way rich , it would be nice to to see the pw on the injectors
    i just looked at your first log and the fuel system looked better there .
    Jim
    Dec 2006
    Pensacola, FL
    489
    Jim - thanks for the reply. It's still got a long way to go. After logging that I figured out that I had installed my MAF sensor backwards in my makeshift intake plumbing (actually Phil at tampatuning did, thanks Phil!). I'm sure that has something to do with it. I'll try to run another log today.
    Oct 2013
    228
    that would make alot of sense with the upstreams being screwed up keep us informed , im going to follow this thread as im not a tuner yet but mechanic for 24 years
    Nice ride
    Jim
    Dec 2006
    Pensacola, FL
    489
    Getting closer! Injector data good, exhaust is on and fixed my STFT/LTFT B2 problems. Working on fine tuning it now. Here's a log. Do I need to apply the TCS patch? This is a standalone setup in a 68 C10. TIA
    Tuner TexasGMC08's Avatar
    Feb 2013
    Fort Worth
    102
    Thank you for Write up... Did a swap on a 92swb!! Fired right up!
    JRXTuning & Performance
    Fort Worth Texas
    [email protected]
    2011 CTSV https://youtu.be/WUuGxYNfJjk
    2008 GMC Sierra 5.7, Nitrous Outlet 200shot, 4.10 gears (Sold)
    2007 GMC Sierra 4.8 4/7 drop, Tune only
    2007 CTS-V BTR STG4,TFS225,MSD Airforce,102NW TB
    Oct 2017
    45
    I would like to contribute to the thread. The 2015 e92 pcm does not have vats2. You need to request a segment swap from a 2014 that has vats 1 and 2 or flash it with a 2014 file that.. but will eat up 2 more credits. Disabling vats 1 on a stock 2015 ecu does not allow the car to run.
    Advanced Tuner 68Camaro's Avatar
    Mar 2011
    Van Buren, AR
    326
    thanks for this ^
    I have been working with a 2016 E92 - been thinking I am stupid
    did you email support with this?
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    HP Tuners says that on the 2014 E92's there are two VATS patches. On the 15+ there is only one needed.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
    Dec 2014
    13
    Had a 2015 running since 2015 in a swap app. Never had a VATS issue.
    Link 1
    Link 2
    Jun 2017
    6
    E38 ecu
    How did you get your vats deleted on the e38 ecu. I have a 09 Yukon motor swapped in a 94 Tahoe turns over starts for a second or two and shut off. I thought I deleted the vats but I guess not.
    Tuner in Training JBMRACING0105's Avatar
    Oct 2017
    USA
    24
    Is this the same procedure for a 2016+ Camaro/Corvette LT1/LT4 VATS disable?
