I am trying to figure out the value I want for my a/f in pe. I am running e85 and I'm using a 9.77 for stoich. When I divide 9.77/11.0af=1.13 pe. Is this correct? Something doesn't seem right.
Guys I know are running around 7.7 at WOT with E85. 9.77/7.7=1.268 PE EQ ratio. That would be a good starting point but you really wanna get it on a dyno to figure out if richer or leaner will net more power. Hope this helps.
Daniel
Pontiac G8 GT
1.33 in PE is a LOT of fuel...what's done to the engine?
2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
2023 Durango Hellcat
Yeah, then 1.33 is going to target the same lambda on E85 that 11.0 would equate to on pump gas...but remember that E85 is a higher octane, so you may find less fuel to be better.
