Hey all,
I've been trying to figure out why my car stumbles ever so slightly when accelerating from a stop with light throttle. My scans show I am getting a lean condition on tip-in. This got me looking into the transient fuel tables after reading posts on here. Can someone tell me in laymans terms what I need to do with the impact and/or evap gas table to fix this slight lean tip in?
I tried playing with only the impact today. I first tried adding 50% to the last half (hot ivt's) of the table. Seemed to idle rougher, but I think the stumble was gone. My idle was more jumpy though. Then I tried using the stock table again with 50% taken out. Idle was much better, the stumble was still there.
Using a clsd tune. Which way does everyone normally go when messing with these tables? From what I understand, if you add to the impact it sprays more fuel on tip in. What about throttle release? For the evap table if you decrease the values it adds more fuel? How do the 2 correlate. Which one will work for me?
Also I noticed that if I go wot off idle from 0 mph I will also get a bog/stumble slight lean condition. Probably not a good thing.
