Hi Guys
We blew up the old LS1 we had in the GTO and are getting ready to put an iron block 390ci in her. While doing this - figured might as well move over to a 100MM LS3 card style maf from the old 85MM we had in her.
Forgot to put in - the engine will be NA for the time being.
As I understand that the LS3 card style MAF curve is significantly different then the Gen 3's we use.
Now the question is does anyne one have a base curve we could throw in to start the car up & then tune it, should I just scale the existing 85MM curve by a certain percentage or should I go into the tune repository & start with a stock LS3 curve.
Sorry for the question andthanks for any help on this.
Steve
