Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 90
Thread: Fuel Level?
  1. #21
    there are two main table types:
    1. the fuel volume vs. sender input (note, i accidently labelled this axis wrong it seems as %). This table tells the PCM how many liters/gallons of fuel you have remaining based on the input in "AD counts" from the fuel sender. IN vehciles where the cluster communicates with the PCM via the class2 bus this table also specifies the gauge calibration. In later vehicles there are actually 4 tables for this.
    2. the other table is the fuel gauge output PWM control, for gauges that are directly wired to the PCM (ie. not class2). Changing this table will affect the signal sent to the gauge based on the % remaining fuel, ie. the fuel volume divided by the fuel tank size.
    The calibration of these things depends on the relationship between the sender output and how much fuel is in your tank, this depends on the shape of the tank and the response of the sender. This is why the curve is a little funky cos rarely a fuel tank is a nice square or rectangle shape.
    You can log "Fuel Tank Level Sensor (V,V)" which is the sensor voltage ( multiply by 51 to convert to AD counts). Also the "Fuel Tank Level" which is the volume of fuel in the tank from this table.
    The % remaining is then a simple divison by the capacity.
    Chris...
    I count sheep in hex...
  2. #22
    Aug 2005
    Midlothian, VA
    205
    If this all works out would you all make it available for all makes?
    Mitchell
    '04 Supercharged MC SS
    MOD LIST
    Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
  3. #23
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    IF one of you guys runs out of gas because you recalibrated wrong...
    I am so gonna laugh my ass off..LOL
    -Scott -
  4. #24
    May 2005
    Conway, AR
    347
    Quote Originally Posted by soundengineer
    I filled up w/gas just for that reason!
    Chris
    2009 Silverado Crew Cab 5.3L, stock.
  5. #25
    Señor Tuner MeentSS02's Avatar
    Jun 2005
    Dayton, OH
    1,132
    Where's the "Screw You" smilie?
    LOL...
    *Edited*
    Alright...now that I have some decent information, I'll go back and look at this. Just by trial and error I was able to figure out how to get my gauge to read "F" when it is actually full. As far as the gauge goes, it looks like I have been able to eliminate the rest of the gauge swing (since it goes well past "F" when it is full) by setting the fuel tank capacity at 16.8 20 points higher than the factory setting (the sender input of 130 is technically where full is [2.53 volts * 51], but I don't want my gauge sweeping all the way to the right...I want it on "F" when it is full, and to drop from there, so 16.8 gallons now corresponds to a sender input of 150). So I'm guessing that 0 will need to be shifted 20 points to the right as well so when it is on E, it is no kidding empty.
    Now for the fun part...logging data each time I go to fill up with gas to see how much it is saying is there vs. how much it actually takes to fill it up.
    Anyone have a good pic of the 1999-2002 fuel tank so I can get an idea of what I'm looking at for a profile since I know this won't be linear?
    2008 Viper - now with HPToona - 1/4 Mile Shenanigans Here
    11.02 @ 130
  6. #26
    Jun 2005
    Dayton, OH
    1,132
    Oh, and I assume my car communicates by the class 2 bus since modifying the fuel volume vs. sender input changed how my gauge operates?
    11.02 @ 130
  7. #27
    Jun 2005
    Dayton, OH
    1,132
    And before I forget, is there any reason why my "Fuel Tank Level" PID in the scanner always reads 0? Bug? Fuel Tank Capacity reads just as it should, and the voltage is correct too.
    11.02 @ 130
  8. #28
    May 2005
    Conway, AR
    347
    mine reads either 0.2 or 0.4 gal. Not sure why, it reads fine on autotap.
    Chris
  9. #29
    Jun 2005
    Dayton, OH
    1,132
    Hmmmmmm...sounds like it could be a little glitch in the software. Might not be looking in the right spot for the message.
    Okay, now for another request:
    On 1999-2002 F-bodies, it is a common complaint that our ECT gauges are essentially dummy gauges (they read 210*F from about 180-230 actual ECT). Since I can manipulate my fuel gauge with the PCM, can I do the same with the ECT gauge? Or is it not controlled by the PCM?
    11.02 @ 130
  10. #30
    Apr 2005
    4,387
    its only a dummy between 190ish and 220 ish....
    mine seems to read pretty acurate at any other temp...of course...I could just be lucky too..LOL
    -Scott -
  11. #31
    May 2005
    Conway, AR
    347
    mine runs at 174 and reads 185*.
    Chris
  12. #32
    Apr 2005
    4,387
    maybe I'm lucky then..LOL
    -Scott -
  13. #33
    May 2005
    Conway, AR
    347
    yeah yeah rub it in!
    Chris
  14. #34
    Aug 2004
    UCSB-Chemical Engineering
    171
    hope you guys get this figured out so we can fix our fuel gauges. the million dollar question, will this be an option for the 98 guys?
    98 Camaro, M6, HPTuners, heads and cam
  15. #35
    Jun 2005
    Dayton, OH
    1,132
    It is working so far...just doing some data gathering.
    11.02 @ 130
  16. #36
    Quote Originally Posted by bmfcamaro
    yes, i just added it for 97/98's. Email keith@ to get an update if you want to try it.
  17. #37
    Aug 2004
    171
    Quote Originally Posted by Chris@HPTuners
    dude your awsome.
  18. #38
    Oct 2004
    Huntingtown, MD
    200
    2 Q's
    1. Is there a value to set at what fuel level the "Check gauges" light comes on? I don't see it.
    2. How about allowing us to recalibrate the Engine temp gauge?
    Phil K.
    02 Camaro SS 5.7L LS1
    01 Silverado 1500HD 6.0L LQ4 4L80E 78/75 turbo with Flex Fuel
  19. #39
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    Quote Originally Posted by pknowles
    2 Q's
    #2 I would definitly like if its something you guys could provide
  20. #40
    Jun 2005
    Dayton, OH
    1,132
    Double
    Didn't think about the "Check Gauges" light though...good point too.
    So far with my fuel gauge, it is working well. I have about 5 or 6 different data points, and am confident it is finally getting to be accurate.
    11.02 @ 130
