Results 1 to 13 of 13
Thread: 42# INJ *Correct IFR Table?*
    Can anyone pose up your tune with the correct IFR table for 42# injectors in a 2000 Ls1? Do I have to change anything else besides the IFR table to properly skew the injectors? Thanks.
    2003 Galaxy Silver Limited Edition GTP
    Mods: 2.8 MPS | S2IC | XP CAM | GEN V | 65# | E85 | TOGS | N* TB | HPT PRO | Impala Brakes | BUILT TRANS w/3.29 GRS
    2017 Chevrolet Silverado LTZ 6.2
    Mods: HPT PRO
    Jun 2012
    Pensacola, FL
    150
    What brand of injectors?
    Okay ill give you guys a lot of specifics and hopefully can give me some insight on making a good base tune. It should be ready to start for the first time this weekend.
    Cam specs (234/242) duration .575/.595 lift with 112 lobe separation
    3.70 Gear ratio
    Walbro 255 fuel pump with dual feed 8an rails
    Stock LS1 MAF
    Polished heads and intake 1.96" intake valves and 1.64" exhaust valves
    10.4-1 compression
    EV1 Injectors flowing about 42# at 55 psi fuel pressure
    Supercharger running 6-9 PSI of boost
    I was told to start with a stock 2000 LS1 file that I picked up from the repository. Help me make a base tune so she will at least idle this weekend LOL
    Mods: HPT PRO
    Jun 2012
    Pensacola, FL
    150
    you still did not answer my question. What injectors?
    Bosch 42#
    Mods: HPT PRO
    Jun 2012
    Pensacola, FL
    150
    Quote Originally Posted by Lumpo View Post
    Bosch 42#
    give me a part number......
    should start with 0280.......
    0280155811
    Any help with creating a good base tune would be appreciated. Thanks.
    Dec 2009
    1,084
    I am seeing that part number listed at 36lb
    I found this info
    http://www.hptuners.com/forum/showth...l=1#post319750
    Dec 2008
    on the Dyno
    1,825
    Yeah those are not 42lb injectors. They are 34.54lb @ 3bar and flow roughly 39.88lb @ 4bar.
    Located in Central Kentucky
    ShorTuning
    Quote Originally Posted by planethax View Post
    I found this info
    Great find! So you guys have any tips where I should start with to get this car dialed in? Should I start with a VE tune then move to MAF? On a setup like mine whats the ideal Idle/Cruise/WOT AFR?
    Another thing im not really sure on is how to get change my commanded AFR? I know you go in Power Enrichment table but i don't know what 1.250 is as far as commanded AFR. Is there a formula?
    Mods: HPT PRO
    5BA8
    3,499
    PE is stoich/PE=commanded AFR. Using pump gas 93 octane, it would be 14.68/1.25=11.744
    email=[email protected]
    Thanks! So what should I shoot for idle/cruise/ wot?
