Hey All,
I have a customers car here and it is all pretty good start up and idle wise until you drive or hold up the idle and then it wants to stall after the throttle is let off. What I notice is that at idle the STIT's are just a bit negative, but if I hold up the idle (as in this log) or drive the STIT's will continually go more and more negative thus causing the car to stall when the accel is let off and the IAC counts are at zero at that point.
I could not see any glaring things to cause this and was curious if anyone else has seen this before. Any other car I have tuned will zero the STIT's as soon as I get off idle.
Let me know and thanks.
Mike Norris
