Just want to make sure that I'm taking the easiest steps to get my segment swap done. I've done lots of reading and think that I've got it figured out but just want someone to tell me if there is an easier way. My o/s is 12579405 out of a 2003 Silverado with a 5.3l/4l60e. I'm installing a 2001 6.0l/4L80e, so I need a compatible o/s with the 80e. Closest I've found is this o/s 12593058 with this info:
OS 12593058
Calibration History for: Operating system
Part Number CVN Bulletin # Description
12593058 N/A - New software to address idle surge condition caused by throttle body choking.
12580055 N/A - Operating System (replaces 12578128 or 12579405)
12578128 N/A - Operating system
Question is do I need to get the o/s updated with Tech 2? If I do, what will happen to my current tune? My truck is cammed so I can't just have them flash it and drive it home, I'd have to copy/paste all my info over. With this, the o/s will match so a segment swap should be no big deal right? Also on the engine side, I'm assuming that it's as simple as just doing a copy/paste from a 6.0l? I'd use the 01 pcm, but my truck is DBW and i'm planning on running a tbss intake/throttle body. Am I on the right track or does someone know where I can get an 80e tune on the 1259405 o/s? Is this the easiest way? Thanks for any help you guys can provide.
