Results 1 to 3 of 3
Thread: Standalone logging - how long can i record?
    Potential Tuner 6camaro9's Avatar
    Jul 2013
    DFW, Tx.
    6
    Angry Standalone logging - how long can i record?
    in the help it says I can record 80 minutes, that's a load of crap. I went out logging today and I only got about 12 minutes into recording before the err light came on. when I came home and hooked up to the laptop the MPVI said it was full. I saved the log onto the laptop and it was about 1.5 meg in size. so where's the extra 68 minutes of recording?
    thanks,
    Thomas...
    •2008 GenIV LS4 5.3L FWD - DoD/AFM removed
    •EPS Cam: 216/220 duration @ 0.050" lift; 0.561"/0.564" valve lift
    •LS2 Intake, 90mm Throttle Body, and LS2 Injectors
    •Modified Doug Thorley Headers
    •3.0" Mandrel Bent Exhaust, Magnaflow Muffler, Vacuum/Solenoid-controlled Exhaust Cut-out Valve
    •2008 GXP ECM OS custom tuned by: Sinister Performance
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Up to 80 minutes dependant on vehicle/pcm type. I can log that long fine logging at 5fps on my grand prix as can thousands of our customers on all gen 3 v8 vehicles, most v6 vehicles, etc, however on gen 4 pcm's they spit out gobs of information so tons of frames per second which eat up memory. One thing you can try is setting the data scan rate to slow, this should get you some additional time, how much though I'm not sure.
    Dec 2009
    1,084
    Get a screen shot of the PRO Data Logging screen.
    How many logs is there?
    What config and how many Pids logged?
