Results 1 to 7 of 7
Thread: TCC locks in 3rd but then unlocks going into 4th only to lock again?
    ok so heres my dilemma:
    -with shifter in "D" or overdrive and i have my TCC unlock at 43% in 3rd or 4th
    -say i go at a steady 20% throttle and TCC locks at 25mph and 4th shifts in at 30mph where the TCC locks at 38mph in 4th
    -running 3.73s and a 3200stall with built trans
    going from a stop or slow roll and shifting into 3rd at like 21mph i then have the TCC engage but then unlocks upon shifting into 4th gear and it'll lock again when it reaches 38mph.
    is this normal? i looked at alot of other's tunes and noticed that a majority of ppl have both 3rd and 4th TCC enage at the same mph, for example 40mph. i never had an issue running this in a fwd 4T65E for the tcc to lock in 3rd and remain locked going into 4th. i can upload a copy of my bin file fwiw.
    Jun 2006
    Western Pa.
    331
    Is shift lock enabled?
    04 Sierra Denali,370,S485B, Built 4L80E, 3barOLSD, E85
    i'm currently at work and not at my home laptop but i am fairly certain its disabled. would enabling it allow the TCC remain locked shifting into 4th? if so thats good news. i have the TCC unlocking if TPS is above 50% for both 3rd and 4th for the TCC apply table fwiw.
    ok, was able to go home for lunch. the TCC shift lock is disabled.
    Apr 2013
    20
    whats the verdict on this issue? should you have shift lock enabled?
    Jun 2011
    Montreal, Canada
    758
    With shift lock disabled, the TCC will unlock during shifts.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    it didnt do anything for me. when i had the tcc lock in 3rd, it'll still unlock when shifting into 4th then it'll lock again at whatever mph i have tcc lock in 4th. im confused at this point. so what i did was put the tcc lock at 39mph where its already in 4th gear regardless and if i have the gear selector in 3rd it'll also lock at 39mph.
