Results 1 to 3 of 3
Thread: CAN-BUS & Diesel to Gas swap.
    Oct 2013
    2
    Hello everyone, I'm doing a gas to Diesel engine swap on A Ford E-series van.
    The van being converted to diesel is a 1997 Ford E350 with the V10.
    The donor vehicle is a 2008 Ford E450 cutaway with the 6.0 diesel.
    I plan on moving the engine, trans, instrument cluster, all wiring, etc from the 2008 van to the 1997 van.
    The 2008 van is CAN-BUS equipped. Will this cause a problem for me?
    Thanks in advance.
    Oct 2007
    Crawfordville, FL
    2,410
    Quote Originally Posted by vacuumbed View Post
    Thanks in advance.
    It should not be an issue so long as you move everything over.
    Eric Brooks
    HP Tuners, LLC
    Oct 2013
    2
    Thanks for your response.
    The only thing I can think of is the rear axle ABS that might be different.
