Page 10 of 15 FirstFirst ... 67891011121314 ... LastLast
Results 181 to 200 of 288
Thread: Bluecat Transmission Table Software
  1. #181
    Aug 2016
    Swansea Wales UK
    186
    As above, it wont send to a Gmail addy, have you got another ?
    Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
  2. #182
    Apr 2019
    15
    Quote Originally Posted by Osman View Post
    8L90E - does anyone know why we don't see anything under Export tables ???
    Were you able to figure this out? Having the same issue?
  3. #183
    Dec 2018
    4
    Quote Originally Posted by jsf55 View Post
    [email protected]
    Cheers again
  4. #184
    Tuner in Training Jabercrombie's Avatar
    Dec 2018
    26
    Does it work with gen v trucks?
    Quote Originally Posted by Bluecat View Post
    Last Updated: 7/6/18: Version 1.37
    I know I promised this to you guys years ago when I quit updating my transmission spread sheets, just hard to find time to make something public releasable. Better late than never I guess. The complexity of making the 6 speed stuff function correctly was beyond what I could do in a spread sheet. To much applying a logic rule, apply another, recheck the previous... So here it is. Was going to make a wizard type utility that just asked questions and filled the data out for you, but gave up on that. If your familiar with my spread sheets, it works the same way. You input the same data. Shift curves are broke into presets that match the Manual and ETC curves for common calibrations. Speedo data and formats for common cal tables are on the export window. Pretty much let the mouse over tooltips guide you if you don't understand. Other than that your on your own. I'll chime in later and add some better description of a few features and the reason behind them. But I again just wanted to make a tool from my toolbox available to everyone.
  5. #185
    Sep 2019
    Virginia
    34
    Could I please get a copy emailed to me? It will not open when I download the link.
    [email protected]
    Thanks!!!
  6. #186
    Aug 2019
    Cleveland, TN
    87
    i have to open it out of the folder it comes in, cant seperate exe file
  7. #187
    Aug 2016
    Swansea Wales UK
    186
    I've sent a copy, but yet again it's been rejected by a server. you need win zip or similar to unpack it and then use it from there
  8. #188
    Waldorf MD
    774
    Quote Originally Posted by jonathan8186 View Post
    [email protected]
    Thanks!!!
    Here you go! Youre welcome...
    https://drive.google.com/open?id=19L...gxv43MrwEHD0TJ
    Daily Driver= 2003 BMW 330xi
  9. #189
    Sep 2019
    Virginia
    34
    Well that didn’t work...
    Any way to email it?
    [email protected]
  10. #190
    Aug 2016
    Swansea Wales UK
    186
    No luck with Gmail either, so I've added it to my dropbox account and sent you the link via that Gmail, I hope you can get it that way ? john
  11. #191
    Waldorf MD
    774
    [QUOTE=jonathan8186;588108]Well that didn?t work...
    [email protected][/QUOT
    https://drive.google.com/folderview?...gxv43MrwEHD0TJ
  12. #192
    Arizona
    482
    Quote Originally Posted by jaydubb71 View Post
    this worked foe me, thanks
  13. #193
    Tuner in Training 1278342005's Avatar
    Oct 2017
    Norman, Oklahoma
    35
    8L90E Issue
    Every time I get the parameters to where a car is over 380hp it gives me a "Data in Logic Error" If my stall speed gets above a certain amount or my HP goes above a certain amount. Any thoughts?
  14. #194
    Sep 2010
    webb city, mo
    504
    Quote Originally Posted by 1278342005 View Post
    Adjust the parameters next to the box where you specify your throttle body up or down until you find a more acceptable setting
  15. #195
    Dec 2006
    Birmingham, Alabama
    156
    Is version 1.37 the most recent version?
  16. #196
    Apr 2018
    9
    Has anyone used this on a gen v? Like a 2014 Silverado 5.3 with the 6l80e?
  17. #197
    Dec 2018
    Dallas Texas
    35
    Quote Originally Posted by Jrob56 View Post
    Yes it works fine. However I also tried setting my wide open throttle shift RPMs then putting the wrong tire size in the gear/tire wizard hit apply then I put the correct tire size in and hit apply and then all my shift points were corrected to where I wanted them.
  18. #198
    311
    I'm sorry I see what you mean now. You can't go past that first page.
  19. #199
    Aug 2010
    24
    Can someone email to [email protected]
    2017 silverado
  20. #200
    Aug 2010
    24
    What shift slope did youb use for 2017 silverado lt4 throttlebody?
