Here's what I'm working on, 2013 Camaro SS 6.2/6L80 retrofitted into a 68 C10 SWB.
Engine Mods:
DOD/VVT mechanically deleted
3 bolt Competion Cam 269LRRHR (219/235 113LSA)
TVS1900 Magnacharger
2013 Camaro SS MAF
LS9 MAP
Holley Fuel rails
Siemens SD 80 injectors (http://fuelinjectorconnection.com/sh...?productid=285)
A1000 fuel pump with 10AN feed (8AN to rails/8AN return)
Aeromotive Boost referenced fuel pressure regulator (Set to 58 psi).
1 7/8" mid length headers
rear 02s and CATS deleted
A/C
Tranny Mods:
Stock stall
Shriftersix paddle shifters (I eventually want to do a Corvette TCM Tune)
4.11 gears
31" tall tires
My plan:
I'm trying to do a basic "safe" tune to get the truck running so I can have the exhaust put on and make sure all systems are working correctly. Then I plan on taking it to an experienced tuner for a dyno tune.
I tried to do the "simple" stuff first:
DOD delete
VVT delete
Rear 02's and cat delete
change gear ratio and tire size
And then plan on doing this next:
LS9 Map sensor
80LB Siemens injectors
Tune MAF
Set fan temps
Here's my first tune. I haven't flashed anything yet. Check it out and let me know what I missed or messed up, . Thanks,
Rob
