Results 1 to 9 of 9
Thread: 2014 sierre not going into PE
    Jun 2009
    203
    Greetings
    2014 5.3 sierra.
    whatever i touch on PE folder causes the truck to not enter PE mode it staus 14.7 forever.
    returned parameters to stock and it goes to 12.X but delays a lot of time.
    stock.hptmotor.hptstock.hptmotor.hpt
    Apr 2013
    210
    just by skimming through on the file called "motor"
    your PE delay ECT MAX is at 250 F? the engine should operate <250F so by reading the description that is one of the culprits. reduce it to 20 F... i would assume.
    also increase the ramp in rate to 2
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    Pretty sure it can also be caused by the TM tables that have been changed as well. Since these pcm's are all tq based when you start changing tq based tables it can screw up other things ie fueling.
    Apr 2013
    210
    so since many of the TM have been maxed out it will not enter PE? these pcm's already sound like a PITA
    Jun 2009
    203
    Its done... I just need to get rid of the fuel cut between shifts.. any idea how to do this?
    can you post your latest file please
    Mar 2010
    Texas Hill Country
    3,299
    Peak Torque in the Engine - TM Tab will prevent you from going into PE if you just max it out. You have to start being strategic/smart with the TM tables. Raise them so they don't limit the car but not so much that they limit you.
    Sep 2012
    11
    At what percentage of torque does your power enrichment enables???
    Mar 2010
    Texas Hill Country
    3,299
    I think around 50%, I have to look.
