Results 1 to 8 of 8
Thread: 2002 Z06 injector data. With FMS 30's
    Mar 2005
    Hendersonville TN
    161
    I'm going back to revisit the tune in my Z06. Ported heads and cam. And I have the Ford SVO 30# injectors. These are the skinny new style red top injectors.
    Before I go any further, could someone look at my tune and see if I've got the injector data correct? See if the offsets and short pulse adder and the flow rate look right? Any advice appreciated.
    Bryan
    Mar 2005
    Hendersonville TN
    161
    Nobody wants to take a look at my tune and tell me if I'm on track with the injector data, or just way the hell off?
    Bryan
    I have the exact same injectors in my LS1 and have the exact same question.
    These are the newer Ford 30# injectors. Long EV6 body, all red, Bosch injector. 0280155759 on the side of the injectors.
    Any help would be greatly appreciated!
    Mar 2005
    Hendersonville TN
    161
    0280155759
    Yes that's them.
    Bryan
    Feb 2009
    1,931
    Everything you want to know is right here.
    http://www.summitracing.com/int/part...vd-1/overview/
    Jul 2017
    12
    Did anyone ever find the info on these injectors? I've searched the forums, and googled to the end of the net. I can't imagine the info isn't out there somewhere, or at least info to stay away from the red 30lb skinny injectors because no one uses them, and there is no data.
    Dec 2008
    Nevada
    4,452
    I'm pretty sure frpp 30 reds are discontinued but they might be found here:
    http://www.efidynotuning.com/injdata.htm
    If you find the ford data there is a converter excel sheet floating around for Ford --> gm data.
    Jul 2017
    12
    I have the conversion spreadsheet from here. Thank you for the info, I'll check that link for my injectors. Hopefully I Can get these to work.
