Results 1 to 6 of 6
Thread: Setting GM 3.6L MAF Frequency Fail
    Nov 2013
    3
    Hi everybody,
    Firstly, I hope this is the correct place to post this...
    I own a 3.6L HFV6 in my 2007 Holden Commodore, which has recently had a turbo strapped to it.
    I am running an aftermarket ECU to control fuel and whatnot, but left the stock ECU in place for all the other functions.
    I am having a problem with P0101 and P0103 DTCs - I've set them to '0 - disabled' in the DTC table, and now no MIL is shown, but they still trigger my traction and stability control to disable, resulting in annoying beeping and flashing lights.
    I have been able to set MAF fail parameters on other vehicles, but I can't seem to locate it in any obvious place - is this feature unavailable, or am I just really bad at looking for things..?
    Feb 2006
    Canada
    1,958
    Should post a tune there so others can have a look and see if they find something you may have overlooked
    2000 Trans Am WS6
    28,268
    depends on the pcm, if its an E55(bosch variant) its not there because the ve tables are not available so tuning with no maf would be next to impossible.
    Nov 2013
    3
    Ah, ok that makes sense I suppose, thanks for the response!
    In my case, the MAF has no say on fuel metering, it's just there to keep everything happy.
    Is there anything I can do that will solve my problem?
    Is there a way I can run no MAF while keeping everything happy? (Traction/Stability control mainly)
    May 2015
    38
    Having a similar issue - has there been any resolution to this?
    Dec 2014
    Palmetto, FL
    874
    Quote Originally Posted by dan_t View Post
    What is your specific issue? This is a pretty old thread.
