Been a while since i posted here... I have an issue with a 05 sierra, with a 6.0 engine, D1SC, ID850 injectors. I have converted it to a two bar SD tune and installed a 2 bar map sensor.
The car idles perfect, however, when i slightly hit the throttle it goes extremely lean. I have attached the log/config and HPT file for your reference.
I have verified the lean condition with the wideband, however, it is not in the log and not connected... you can still tell its going lean by looking at the O2 MV though. Its currently in open loop and i will start tuning the car partial and WOT using a wideband.
I have asked the mechanic to verify the fuel system and fuel pressure right now, but i want to know if this is a tuning issue or mechanical issue? I did try adding fuel above 60 and 70 KPA but still have the same issue. Maybe there are other settings which i missed out? Are the MAP sensor settings correct?
Looking to see some feedback.
