I have a 98 TA that I swapped an LS2 into, I recently installed milled LS3 heads and and LS3 intake. It has a 226/230 EPS cam and I have normal boltons, LT headers, 85MM MAF, 92MM TB, and 98MM FTP lid. I am just curious if it is normal for my VE table to be up to -24 from stock? I am low to mid 20s lower than stock around the 25 to 50kpa and 800 to 1600 rpm. Is that normal? I know that with a cam the low rpm areas are usually lower than stock but just wondering if it is normal to be that much lower? For instance, the stock tune has 56 at 1200 rpm and 35kpa. My tune is at 33 in that same cell.
Thank you for any input.
