Results 1 to 13 of 13
Thread: TCC Not locking up and hitting rev limiter Help Needed
    Oct 2019
    Houston Tx
    26
    Guys this is my first post and I have dug around to see if I could find an answer but still no luck. I've tried setting all the shift settings back to a factory tune, I've tried blue cat, I've tried shift points from an 05 Denali... still can't get it to lock up. I can command it to lockup and it does, but not on its own. Can yall take a look and see what looks off please? Should also note that I lowered the rev limiter in the attached file.
    So problem 1 is no TCC lockup
    Problem 2 is hitting the rev limiter on dowshift, however I rarely push it that hard anyway.
    This is in an 84 Chevy k20 6.0 with a mild cam, 4L80E and NP205 TC.
    Attachment 94016Attachment 94017Attachment 94018
    Aug 2019
    Cleveland, TN
    87
    have you tried raising min temp to max temp in the misfire tab under engine diag. misfires will hold off TCC , cam swaps can sometimes trigger this.
    in bluecat you can setup maximum downshift speed by rpm. only works if all the correct data is input though
    Oct 2019
    Houston Tx
    26
    Quote Originally Posted by Erik Dicus View Post
    is there another place it could be? i dont see it
    Attachment 94021
    Aug 2019
    Cleveland, TN
    87
    edit - view - advanced , then try again
    Oct 2019
    Houston Tx
    26
    OH dang... can't tell Im new can ya?
    Aug 2019
    Cleveland, TN
    87
    we all gotta start somewhere, its alot to take in
    Oct 2019
    Houston Tx
    26
    Attachment 94026
    That didn't get it, the section that shows it locked up was becasue I forced it through Special Functions
    Aug 2019
    Cleveland, TN
    87
    TCC brake light switch circuit?
    Oct 2019
    Houston Tx
    26
    they were all turned off... let me enable them and try again. I really appreciate all the help!
    Aug 2019
    Cleveland, TN
    87
    being its a swap, make sure the switch is adjusted correctly and/or wired correctly
    Oct 2019
    Houston Tx
    26
    the only that came on after turning on everything relating to the Trans was P0705 - Transmission Range Sensor A Circuit (PRNDL Input) (Pending, Current)
    Could that be it?
    Oct 2019
    Houston Tx
    26
    Quote Originally Posted by Brandon_ View Post
    Could that be it?
    Erik Dicus... not exactly sure what made it work. Maybe turning on the reporting? Either way it?s working like a champ now.
    Man. I so appreciate your help!!
    Aug 2019
    Cleveland, TN
    87
    may have to make some tweaks as to whats used and not used based on swap. glad i could help
