Results 1 to 5 of 5
Thread: tuner capabilities
    tuner capabilities
    have a 2002 firebird that has been converted to v8. in order for this car to be able to be tested for emissions in the state of georgia the vin# logged in computer has to match the vin# on car itself. Is your system able to load my computer with vin# from car?
    Oct 2013
    550
    Maybe ... with HPT the VIN and the OS (operating system) must be for the same vehicle model and model year. If your are using a 2002 Firebird / Camaro OS in the PCM, then it might work (not certain if the VIN / OS criteria go as far as engine type - don't think so).
    28,268
    Not likely, as the operating system won't match the vin.
    If i sent the pcm off to have vin of v6 firebird burnt into it- could i then use your equipment to tune it?
    28,268
    No, it would give you a vin/os pair error when you attempt to read the pcm.
