I'm going to give you some adaptive idle changes that should eliminate the problem. Will work on this after I leave work today and then provide you the changes.
Looks like we have option of providing some throttle cracker air down at low RPM if we need to; do you have a copy of your stock file handy so I can look at what GM did for your vehicle from the factory? Throttle follower and cracker for reverse use 1st gear values.
Thanks for all your help guys. I got it finished up and running pretty damn good. Thanks for providing me the base tunes to work off of and getting me close Russ. James, I did play around with the cracker and follower tables very lightly and got the car to maintain idle in nearly all conditions.
Thanks again. Now on to the next one! Lol
