Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 61
Thread: SRT4 read support
  1. #21
    Sep 2013
    Rio Rancho, NM
    10
    Hey guys if you need any SRT Caliber stuff, we have 2 SWSers that are here daily that I can fiddle with. One stock and one with some AGP goodies. Actually used VCM Scanner today to data log (only a few PIDs - but mostly used for STFTs and Timing) in conjunction with the ........ handheld to dial it in. Using the handheld really made life hard in comparison to using VCM Editor. Cannot wait to be able to use it with our Mopar crowd.
    We have em lined up out the door on our mailing list for news.
    PM me if any HPT guys or gals need anything pulled or whatever.
    Ivan @ Southwest Speed
    PS - I also have a 2012 Hemi Chally and brand spankin new 2014 SRT Charger available for reads if it could help the cause.
  2. #22
    Mar 2014
    1
    i have access to a 03 and possibly an 04 nsrt4
  3. #23
    Sep 2010
    Houston
    131
    k, shoot me an email with your serial number and I'll get you the update
    Hello Bill
    how this is comming? any progress?
    I sent you an email
  4. #24
    Sep 2010
    Houston
    131
    Bill
    I sent you my 2005 srt4 read
  5. #25
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    I believe we've already mapped out all the 04-05 SRT4 defs, read, write, editing, licensing, etc. is done and in beta. I'd like to get some more feedback before we widely release it. Thats really all I'm waiting for at this point.
  6. #26
    Advanced Tuner black06g85's Avatar
    Jul 2006
    New York, New York
    277
    well shoot me that over I can meet with the one I sent you tomorrow
    2006 cobalt (no more turbo)
    m62 2.7 pulley, E85, 79lb/hr injectors, 4-2-1 longtube header, airbox mod, stock catback
    1998 Trans am 5.3 iron block 317 heads 88mm turbo e85 105lb/hr injectors, twin 255's.... build in progress
    2014 wrx mild tune 18psi pump gas
  7. #27
    Are we able to read/ write now for the srt4 vehicles? I have pulled two tunes and sent them in so far, I do have several people interested in my area in getting theirs tuned. Is there anything I can do to help? Or anything you want tested?
    Owner/Tuner Street Performance Syndicate
    06 GTO: D1SC , Full Suspension, 23X .6xx lift Ed Curtis Cam, Mast Heads, Gforce 9" 4.11 Gears, Holley High Rise, Stage 12 Fuel System, Boost By Gear
    01 Duramax: Blown Tranny (again) BWs467 Turbo, Head Studs, Exergy Injectors, Lift Pump, Moonshine
    2014 Taurus SHO: (Wife's Car) OR DPs, Tuned, CAI
    2006 TBSS; AWD SLP Catback, K&N CAI, Tuned
  8. #28
    HP Tuners Support
    (foff667)
    28,265
    Yes
  9. #29
    Sep 2010
    Houston
    131
    I got my SRT4 fully build with a 6265 sitting in the garage waiting for this, I am a bit confused on how the injector scalling is done way different than GM, any input so I can do a write and start logging,
    Now does the RPM axis being off affects anything other than logging for timing mapping?
    PS: With Diablo I was told by several tuners that the definition was limited to 8000rpms reason why the stock PCM wasnt recomended for engines over 680whp, what is you input in this matter BIll?
  10. #30
    Advanced Tuner caesar's Avatar
    May 2003
    227
    Bill, does the SRT4 ECM support 96 lb. /hr. injectors?
  11. #31
    Sep 2010
    Houston
    131
    Quote Originally Posted by caesar View Post
    Im sure it does, with Diablo i seen 2150s FICs
  12. #32
    Has anyone successfully flashed in any tuning yet, I dont want to buy the credits if it is not going to work, I am still trying to wrap my head around all the backwards tables from what I see in Ford and GM tunes.
  13. #33
    Jul 2006
    New York, New York
    277
    havent' had a chance to yet, but will this saturday. seems like a few of the table axis's are not correctly labeled (I will post more specific info later today) and I'm not seeing anything thing that seems related to boost control. But I'm also going off the original read I had before I could actually open the file. Meeting up with the guy this weekend so will start fresh and see what's up
  14. #34
    anyone been able to write full yet ?
  15. #35
    HP Tuners Support
    (foff667)
    28,265
    Yes, I know of a few that have.
  16. #36
    Sep 2010
    Houston
    131
    Quote Originally Posted by posenheimer View Post
    I second that, have you figure it out which tables are for injector scaling? I know the InjPW Offset ( commonly known as Battery latency ) is one , but im debating if the other 2 tables are InjPW vs Fuel Mass and Fuel Mass vs InjPW. The axis shows G for fuel but meaning what ,Grams/sec Grams/cyl?
    Im going to start messing around with this 3 tables but before I start asking other wont hurt.
    Im feeling like when the first time I started using HP for GM hahahaha any information will be apreciated
  17. #37
    Sep 2010
    Houston
    131
    Here are the WOT timing map , the actual map does not show the actual values , but when you click the axis to edit it, it does display the correct numbers, Why is this Bill?
  18. #38
    Sep 2002
    Chicago, IL
    6,395
    Its a bug.
    We got this guy Not Sure, ...
  19. #39
    Sep 2010
    Houston
    131
    Its a bug.
    Can the bug be fix?
  20. #40
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by GCtech View Post
    Can the bug be fix?
    It will be fixed, but I wouldn't expect to happen immediately. It's a product of how the template is defined so i would keep checking it periodicly after software revisions and see if its fixed.
    Jaime
