Results 1 to 14 of 14
Thread: Fuel Pump Problem?
    Advanced Tuner coachcrow56's Avatar
    Dec 2004
    Longview, Texas
    305
    Fuel Pump Problem?
    After 105,000 miles, I have my first real problem with my 2000 GTP. When I punch it, the car falls flat on its face at 4000 rpm---scanner shows that it goes crazy lean. Fuel Filter is new, and about 500 miles ago I installed a Caspar Fuel Pump rewire kit. When I attach a fuel pressure gauge and cycle the key on and off 3 times, I have 40 psi with key on, then key off and it slowly drops---after 15 minutes it is down to 32.8 psi. This car has 2 fuel pump micro relays--14 and 15 (F/PMP SPD CONT).
    When I crank car, I have 42 psi at idle. Disconnect vacuum from regulator, I have 52. Turn off engine, gauge drops immediately to 33 psi. After 15 minutes, it is down to 20 psi.
    Could I have a bad high speed pump relay, trash in the tank, etc. ???? Any thoughts or suggestions are welcome.
    2.8/3.0/3.2 Pulley/ZZP CAI/1.6 HS Rockers/Hi Energy Comp Cam 76-802-9/LS7 Lifters/ZZP Stage 2 Intercooler/TOG Headers/Triple Edge Performance Stage 3 Transmission/3.29 Ratio/NGK TR6ix IRIDIUM .40 GAP/ZZP Fuel Rails/ZEX 100 shot NOS/GMPP Sway Bars/KYB Adjustable Struts/Power Stop Performance Pads/Rotors
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    It's normal for the fuel pressure to drop off after 15 min. Tape the pressure gauge to the windshield and do a WOT to redline to test the pump.
    Russ Kemp
    Dec 2004
    Longview, Texas
    305
    Russ---thanks for your help. I got a Fuel Pressure gauge from my son's shop with a long cord, did a WOT run----above 4000 rpm the AFR's went lean into the 13's as fuel pressure dropped below 40 psi.
    I purchased an ACDelco fuel pump for $340. I installed it today, and fuel pressures went up to 46 with key on and 48 at idle. I used your MAF tuning method to tune my AFR's, and now it locks at 11.5 at WOT. Car runs better than ever.
    I had been battling fluctuating fuel trims for several months--it would go lean at one red light, and then go extremely rich at the next red light. I never knew that fuel pressure had so much effect on tuning, but thanks to you, I have learned something new.
    13,582
    Holy crap, 340 for a fuel pump..
    You coulda bought an upgraded pump for cheaper, but atleast the car runs alright.
    Dec 2004
    Longview, Texas
    305
    Fuel Pump Resistor
    Car has run great until this week. When cranked cold it dies. Takes 2 or 3 tries to get it to keep running. Fuel pressure at idle has dropped to 40 psi.
    When I turn on ignition key, you can hear pump kick on and gauge reads 52 psi, and immediately begins a rapid drop with key on down to almost 0. Any ideas??
    Dec 2004
    Longview, Texas
    305
    Quote Originally Posted by coachcrow56 View Post
    I have come to the conclusion that it is a bad check valve in the fuel pump---any comments?
    13,582
    Or the regulator on the fuel rail has failed.
    Dec 2004
    Longview, Texas
    305
    I have an AEM Fuel Pressure Regulator (AVM-25-302BK). I pulled the vacuum hose off while the car is running, readings on the gauge change, and there is no fuel in the vacuum line. So I think its good.
    Oct 2014
    16
    Fuel Filter??
    Dec 2004
    Longview, Texas
    305
    Changed 1000 miles back.
    Oct 2014
    16
    You'll have to check the relays and grounds next.
    Dec 2004
    Longview, Texas
    305
    Relays and grounds have all been checked. Back when I installed new pump and AEM regulator, I also installed Casper's GTP Fuel Pump Hotwire Kit to boost voltage. All electronics are working correctly.
    Aug 2010
    On the third rock from the sun
    94
    Can You post a scan a drive?
    Dec 2004
    Longview, Texas
    305
    Sometimes it helps to call people who are smarter than me----LOL!!!. I called AEM, and the tech said it was normal for the fuel pressure to drop when the key is on---not started. I adjusted my tune (idle), readjusted the AEM regulator, and now all is good. Live and Learn!!!
