Results 1 to 19 of 19
Thread: New Parameter Added - Traction Control Disable
    Oct 2007
    Crawfordville, FL
    2,414
    I have added a parameter to all of the currently supported V6 and V8 Mustangs (2005-2010). It is in 2.24. Build 515
    The fact that we were missing this was brought to my attention over the weekend. Not sure how I overlooked it myself! Doh!
    Set this value to zero to permanently disable the traction control system. Vehicles with the interior upgrade package will get a few errors on the dash due to the way this eliminates the traction control. This is normal.
    Feb 2013
    21
    thank you! so many people have asked because they are tired of pushing the button!
    Oct 2007
    Crawfordville, FL
    2,414
    If you find something is missing, please don't hesitate to email support. These types of issues are #1 priority.
    Feb 2010
    Perth Australia
    480
    Does that parameter exist in the Aus ford Builds Eric?
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
    Oct 2007
    Crawfordville, FL
    2,414
    Quote Originally Posted by hiddeous View Post
    It may, I have not looked. Do you have a traction control button?
    Feb 2010
    Perth Australia
    480
    Sure do!
    Oct 2007
    Crawfordville, FL
    2,414
    Sure do!
    I'll check tomorrow and if it is there, I'll enable.
    Feb 2010
    Perth Australia
    480
    Champ!
    Oct 2007
    Crawfordville, FL
    2,414
    2.24.518 and above has the traction control scalar added to all Mustangs, and Aussie vehicles we support. :-)
    Feb 2010
    Perth Australia
    480
    Like!
    Aug 2012
    238
    On my 2009 FGt I tried the values 0,10,20,30 and it did not work. Just threw the ZF6sp into spaz mode stuck in first gear with trans error comming onto dash.
    Put back to 40 which is factory setting and back to normal.
    I tested this solution:
    Quote Originally Posted by BlueStreak View Post
    Go to the torque management section under engine. then click etc torque reduction vs rpm and zero out the TCS. and go to clip torque and do the same. thats about it
    Works without setting lamps on dash.
    Eastern and Central Europe American Muscle and Harley-Davidson tuning
    www.hd-customs.pl
    http://www.facebook.com/hdcustomspl
    Aug 2012
    238
    tried that, does not work on my fg falcon. thanks nevertheless
    Oct 2007
    Crawfordville, FL
    2,414
    Quote Originally Posted by turbotrana View Post
    I'm looking at other ways to disable it. This method works on the US vehicles, but being that those cars come with a separate TCM , there may be some additional changes that have to be made. I will investigate.
    Senior Tuner CCS86's Avatar
    Austin
    1,089
    Any updates on disabling TC without dash lights?
    I don't have a "etc torque reduction vs rpm" table. Maybe it got renamed since then.
    Maybe setting this to zero:
    [ECM] 44814 - Desired Air Mass Multiplier (Traction Control): Amount of Desired Air Mass for use in traction control.
    Austin
    1,089
    After more reading, I tried setting [ECM] 44814 - Desired Air Mass Multiplier (Traction Control) to 100% not 0%, but TC still definitely kicks in and closes the throttle.
    Setting "traction control disable" to 0, does effectively disable TC and SC. But it leaves you with an annoying flashing ABS light (despite ABS still working).
    Any way we can disable that light? I scanned the DTC settings and don't see anything likely there.
    Advanced Tuner Witt's Avatar
    Pittsburgh, PA
    380
    SCT has a parameter that you can ask support for but to be honest, I never messed with it so I'm not sure it will do what you want.
    Austin
    1,089
    Quote Originally Posted by Witt View Post
    Thanks Witt!
    Tuner in Training Hammersrt's Avatar
    Oct 2020
    Waco, Tx
    19
    I flashed my car with it running...yes dumb mistake.....My ABS and Traction control lights are on and there isn't any DTC. Abs doesn't seem to be working.....any Ideas??? NOVICE just started to lean how to tune. Was shocked at what I was told from a shop so bought my HP tuner....any help is appreciated....Many upgrades on motor
