I'm working on a 2002 Camaro with a 2 bar OS. The problem its having is that when I make changes to the VE nothing happens. I took out 60% and no change in the air/fuel ratio. I think its not going into SD mode. Ive search on here and have see the MAF problem with the DTC and I followed the HP tuners guide to the 2 bar OS as well. Ive done that and still the same thing. I believe I have my injector data right too. If anybody can look over the tune to see if I'm missing something I would appreciate it.
The motor is a 408 w/ a Procharger f1a and ID1000s on a return style fuel system set at 58 psi.
