With the NGC3 support testing in full swing, what is the outlook on gear/tire calibration support? Is this something that has been looked into, at this point?
Jaime
i have a 13 wrangler right now that i would love to be able to change the gear ratio in. it keeps going into limp mode... all i see that i can change is the transmission gear ratio
Gear changes are done using the current 2.25 Beta Scanner. There is a gear change utility in the special functions section of the scanner for the DCX applications.
Jaime
I tried on my truck with 2.25.2720 and am getting a blank screen on the special function screen. I emailed support and was told that my truck is not a CAN based system.
This is what my log files shows:
SAE J1979 Info: CAN, 500 kb/s, Standard 11 bit, ECM: 7E8, TCM: 7E9
ECM: 7E8, CAN - NGC3, Dodge
VIN: 3D7KS19D36G****** - 2006 Dodge Ram 1500 Pickup Light Duty, 5.7 L, V8
Serial: T TEM3365T5W9L
OS: 56029218AF
Calibration IDs: 56029218AF
Calibration VNs: A430DB92
Basic PIDs: 42
Pending Trouble Codes:
Trouble Codes:
Controller Type ID By OS: 21010
Diagnostic Requirements: Init CAN 0x10 0x92
Scanning Methods: ISO 15031-5 Mode 0x01 Functional, ISO 15031-5 Mode 0x01 Physical, ISO 14230-3 Mode 0x22, ISO 14230-3 Mode 0x23, ISO 14230-3 Mode 0x2C 0x21, CAN Listener
TCM: 7E9, CAN
Calibration IDs: 56029225ADA
Calibration VNs: 938C615E
Basic PIDs: 8
Trouble Codes:
Are you guys making progress on the non Can NGC3?
