would you help me with tuning my coyote?
try zeroing out your tip in retard under the spark tables I think stock its something insane like -15* of timing in the upper rpm range. It pulls quite a bit of timing and can make your throttle feel laggy. Also you can lower your throttle filter to 6. I wouldnt go lower than 4 or you might get bad oscillation or a runaway throttle.
?Our greatest success comes from failure? -Confucius
