2013 6.0 engine in 06 truck cam and crank sensor problem
hey guys, I have a question. after installing a 13 6.0 engine into my 06 silverado and wiring both cam and crank sensor up, the truck will not start, no spark.
I used the 06 crank sensor and the 13 cam sensor (on the front of the cam). the only thing I had to do is wired the cam sensor, everything else was bolt in. I was wondering if the cam sensor is different or if there was a difference in the reluctor wheel on the crank or difference on the cam? Or maybe even a difference in the tune setting that I have to change telling the computer to read a difference or something.
I need this truck to start. any help would be really appreciated.
You have to swap out relucator wheel
^^^^^NOOOOOOOOOOOOOOOO Dont tell me that... ((
If its already in, buy and install the lingenfelter converter box.
^^^^HEY thanks alot. didn't know such thing existed. just placed the order. Now, do I need to change anything in the ecm?
For the converter box, no. Im sure some adjustments will need to made on stock tune for the engine, normal tuning stuff.
