Results 1 to 5 of 5
Thread: no comm
    Mar 2007
    GA
    151
    no comm
    I have a 98 C5 that I had starter issues on, so I had to swap the starter out a couple of times. Now when I switch it on, I have LOTS of messages and when I check the codes, it has "No Comm" on EVERY function
    Have I blown a fuse, or is my PCM fried?
    Apr 2013
    37
    Fuses would be my first guess. I would say check the computer connectors but not easy to get to on c5.
    My 98 ta would give me problems with trying to scan it. key was on position but said no power or interface not found. My computer was fried
    Jul 2009
    Noble, OK
    317
    Have you checked the PCM wiring under the battery. Common to be damaged from a leaking battery.
    Quote Originally Posted by BOTTLE FED View Post
    If the problem started when the starter was replaced you have the wires on the power lug/small ground to the block in the wrong spot. The main power and ground for the BCM/ECM from from those lugs. I often hear the cooling fans run with keyon when its wrong.
    Mar 2007
    GA
    151
    As a follow up. this turned out to be a problem with the SCM shorting out. I removed the grounding terminal of the small, 3 wire link that goes to the seat and it corrected the problem and let the car start. I just removed the wire from the seat motor and put it back together and it worked perfect (???)
    C5- forged LS2, ported Dart pro 1s, custom Tick blower cam, P1SC1 at 13psi, 4" intake and charge pipe, alky control 100% meth w dual injectors, 255 walburo, BAP, yella terra, FAST 90, ported LS2 TB, RPM stage VI, SY3500, 3.42, 335 Ra1, Lots of Body mods
