Injection Timing and Camshaft
If the replacement cam opens the intake valve 15 degrees earlier than the stock cam, how would you adjust the SOIT and/or EOIT tables in the E92?
Your close but its more detailed....just make sure your not spraying when the exhaust valve is still open.....
Howard
I had good results with earlier LS motors but I didn't know if direct injection changes anything....? Your reply could lead me to believe I can spray away as long as there is a closed exhaust valve....not sure that's exactly what I want to do!
