Did you leave COT Enabled? Disabling that will prevent AFM also.
Interesting, I've seen this with the automatics, but haven't noticed it with the manuals, it's driving me crazy on the autos... With boost it is amplified, The 5.3 trucks seem to be the worst, and the 6.2 trucks seem to be the best, the Vettes are somewhere in between...
the 6 cylinder cars do it as well, I'm convinced the cause is from unmapped tables. torque scanning is very limited on the 6 cylinder stuff.
2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
So have you made it work?
having an issue with a truck, this one opens but after a shift it close the throttle half and opens up back.
That's just trans torque management
Bump, maybe someone can help me figure this out.
I understand how the TQ tables work and i know in the sticky it says "Maximum Engine Torque: The maximum possible engine torque, this should be higher than Predicted Engine Torque Cmd otherwise it is limiting" But it really doesn't say what table defines the Maximum engine torque limit. I found another thread where it was never answered. This is the first c7 I've messed with so still trying to figure out all the new changes.
Basically the Throtte closes above 5k and obviously power falls away.
Yes thats in the tcm. My 2017 zl1 was terrible from a dead stop or on a roll. Unlocked tcm and raised my torque limits on the tcm and now tps follows the foot to the tee. Ripping off 1.60 60 foots tires on fire and when was stock it was lucky to get 1.70 with zero wheel spin. Also on down shifts it now snaps open fast rather then the slope you probably see now as I did.
First 9 second 6th gen lt4 zl1 stock blower SHC SBE boost only.
2013 cadillac ats 2.0t Big turbo-gone
2007 tahoe 5.3 lsa blower on 14 lbs boost 6l80e swap 2009 os
2017 zl1 a10 big gulp/2 inch headers/ 9.55 lower/ e85/bigger hx /103mm tb / Synergy trunk tank and underhood kit/methanol injection with torqbyte controller and prometh pump / Jokerz performance R&D ported stock blower/ lme cnc heads /GP tuning custom cam. So far 9.30@150
