keep getting code 8 on my LC1. I moved the bung to the y in the ypipe because it was overheating in the header as well. I am still an n/a 346 with heads and cam so I dont see how the EGT is getting that hot at the y.
Sulski Performance Tuning
That is odd, are you running CATs?
Here's a thread:
http://www.innovatemotorsports.com/f...de+overheat%2A
I've never had this code show (on the Camaro or Cobra) and I put the sensor in the rear 02 bung.
-Michael Rudolph-
2003 Redfire Cobra
Eaton Powered to a:
11.301 @ 129 1.68 60' MT DRs
11.85 @ 124 1.90 60' street tires
no cats, ill check that out thanks
lookin like that heat shield may help out, I am going to do that tomorrow and hope that will take care of it
go make a little copper heatsink to help out...I did this on mine recently just as a safety measure because I had a buddy with one that overheated..different wideband controller...but same sensor
-Scott -
ill go by the hardware store tomorrow to see if i can find some copper
