Ok.. I’m at a loss here. Little back round.
Car is a 2000 Camaro with PRC 2.5 heads, Futral cam (230/232 on a 112), SVO 30’s, bolt ons. The guy put 600 miles on it with a stock tune and stock injectors. I swapped in the SVO’s last night.
Before I left his house I:
Set the idle to 1k
Changed the fans
When I got it back to my house, I started by following the programming for dummies thread http://hptuners.com/forum/showthread.php?t=3833 starting in the idle area.
IAC Park Position Airflow vs. IAT: Raise all points from -40C and up to 21
Idle airflow vs Engine Coolant Temp, all points 68C and up to 8.6
Primary VE 400*.6 – 800*.8 – 1200*.9
Coppied Low Octane to High Octane table
Took the car for a 5-10 mile ride and it ran fine. The LTFT’s were way off but I wasn’t too concerned with them knowing I was going to be making the next step when I got back to the shop.
I got back and then:
Set the Maf Frequency fail from 14k to 0
I reloaded the stock high octane spark map in to both the low and high areas
Reset the Fuel Trim Cells
Disconnected the maf
Went for a ride.
The car kept wanting to die. If I let it die, I would have to give it 25-50% throttle to get it to start. Acted as though it was flooding. Once driving, I got about 1 mile away from the house and it started sputtering bad. I mean real bad. If I tried to keep it at a constant RPM it would buck and sputter. If I cracked the throttle real quick, it would sputter, take off a little then buck and shutter again. I noticed the O2’s were jumping all over the place when this was going on.
I pulled over and plugged the Maf in. No change.
I pulled over again:
Reloaded the Maf setting to 14k
Plugged in the low octane setting
Car ran much better, still would sputter a touch. But very little. My laptop batterey was dying and did not want to get stranded so I headed straight back.
Is it normal for the car to turn to complete crap when trying to tune in SD?
Was it caused by clearing the Trim cells?
