Actually, the decimals are there.. The spreadsheet is just formated to only show you less. I can easily update that. But when you copy and paste, you are getting the 5 decimals.
I'll fix it to show the 5 decimals
Now, I have another question. What happens if I plug the Maf back in and set the fail to 14k?
Or if left in SD, what is the best way to tune on the dyno?
Does it go in to PE mode with SD?
What dictates PE mode? TPS / KPA / RPM delay?
TPS is reflecting the actual % of throttle? So 50 would be 50%, 75 = 75%?
With Hot Select PE being at 284, I'm assuming the HOT PE is the only table that will need to be edited for correct TPS reading?
EQ ratio vs RPM is the field I need to edit once on the dyno?
For spark:
Main spark table would be the place to edit?
.6v = 50% throttle?
Any more I should think about?
Just wont to make sure I understand fully.
