So I have an h/c/i LS2 with a fairly tame cam, mid 220s 112LSA 2.5* overlap.
Been trying to nail down the idle and had it pretty good but still saw huge jumps in timing (mainly down). Idle is set at 26* but saw as low as 16*.
Saw a few threads suggesting messing with the overly done over and underspeed tables. Most of them suggested halving the data and then interpolating between the ends. I did just that and after I flashed the new tune it seems to have made it worse. The RPM swings are much much bigger now and I still see the same exact timing drops. So it made no change in how the timing acted, but made the car idle alot worse.
Did I do this wrong somehow? Or are these tables not really to be messed with?
I have 2 long logs that I did, one with the good idle and one with the bad idle that I can upload. But they are long long logs with driving all over so not sure if anyone really wants to sit and dissect those. I have however did some graphs in excel with the data and you can see the idle RPM and how different they are.
