I played with a friends GS Falcon ute today, it is governed at 50* throttle. I adjusted it to get full throttle (80*) and adjusted all the TPS sensor Max Voltages so it wouldn't go into a limp mode, drives fine, but since doing this the idle hangs in P/N once you touch the throttle i.e. idling in the driveway. but put it in gear the back to P/N it is fine until you touch the throttle.
also what is the TPS Accumulated Error Max? it throws a code and goes into a limp mode if you leave this standard
ive attatched the stock file and the modified file, have a look and tell me what you think
for the record, I have made the exact same changes to a GT yet it doesn't do this
GSFalconUte.hptGSFalconUte1.4.hpt
