hi!
first som info on my car.
i have a Nissan Silvia s14 with a LS2 and T56, with an home made harness.
engine mods:
comp xfi xer 281 cam
comp rods, comp dual spring, comp trunnion upgrade, comp high energy lifters, arp rodbolt
+ mildly ported heads, intake and TB
hooker headers 1 7/8"
true dual exhaust - 3" > X-pipe > 2.5" Flowtech Raptor
VATS, rear O2s and some emission have been removed from ecm
car starts and runs good
but i get som DCT + oxygen readieness error:
[] P0030 - HO2S Heater Control Circuit Bank 1 Sensor 1 (SES) (Old) (History) (Current) (Immature)
[] P0050 - HO2S Heater Circuit Bank 2 Sensor 1 (SES) (Old) (History) (Current) (Immature)
[] P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (Old) (Current) (Immature)
[] P0059 - HO2S Heater Resistance Bank 2 Sensor 1 (Old) (Current) (Immature)
[] P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency (SES) (Old) (History) (Current) (Immature)
[] P0801 - Reverse Inhibit Control Circuit Malfunction (Old) (History) (Current) (Immature)
Once Per Trip Tests
Catalyst: Complete
Heated Catalyst: n/a
Evaporative System: Complete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Incomplete
EGR System: n/a
and i have som strange behaviour on my Wide band O2s (2xAEM UEGO) both sides exactly the same problem.
in closed loop the jump inbetween 14-16 afr while coasting and in idle its strart at 13 an slowly goes to 18 to almoast stall the engine and then goes back to 13 and over again..?
in open loop its stable around 13 at idle and while coasting
i want to have these things sorted before i go to my tuner for a proper tune...
For the P0106, just max out the enable temp in he Engine Diagnostics>General tab. For the P0801, you need to diagnose the reverse inhibit circuit & solenoid.
i have adjusted knocksensitivity a little at idle, what more do i need to do?
new list of dct...
this time the malfunction lamp came while coasting at 1700rpm on highway, on my second longer trip.
the first long trip (35km) did not illuminate the malfunction lamp
can i disable the p1381 code?
[] P0300 - Engine Misfire Detected (SES) (Old) (History) (Immature)
[] P1381 - Misfire Detected - No Communication with Brake Control Module (Old) (History) (Current) (Immature)
Once Per Trip Tests
Catalyst: Complete
Oxygen Sensor: Complete
Oxygen Sensor Heater: Complete
EGR System: n/a
i did also have some problems with startup airflow , now adjusted and almost always works perfect
sometimes on middle temp 45-65 Celcius i need to crank 2 times...maybe add more airflow?
