Results 1 to 8 of 8
Thread: 4.2l I6 Trailblazer throttle body opening slowly
    May 2014
    New Enterpise, PA
    65
    I see that on the I6 trailblazers the throttle body opens slowly. I see that EFI Live hase a way to correct this. I guess they use B2804 table. I have never used there software. Is there a way to correct this in hptuners as well. I have done some looking. If there is a thread on this please direct me.
    thanks,
    Mike
    Mar 2013
    Naples FL
    8
    I would like to know that too????
    May 2014
    New Enterpise, PA
    65
    There is a way but I am beginning to think hptuners doesn't support it. :-(
    May 2006
    Seattle, WA
    539
    First, what PCM are we talking about here? Year of the TrailBlazer please.
    02-05 P10- B2804 in a P10 (02-05) is the Octane Scaler which has 0 impact on throttle opening. To adjust the throttle opening speed, it's tied into Torque Management. Look under Engine and Transmission -> Torque Management, HPT has the tables (and then a few more).
    P12 (06-07) are different and dont have that table, I havent tuned one so cant help you there.
    E67 (08-09) has B2804 as the throttle rate table which WILL impact throttle opening. For HPT, Engine -> Airflow -> Electronic throttle -> Area rate opening limits.
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
    May 2014
    New Enterpise, PA
    65
    I have an 04 trailblazer with the b2804 pcm. Ok Awesome information. I think i have torque management pretty well disabled for the most part. i will look into in to see what all tables are there. Thanks ScarabEpic22
    May 2006
    Seattle, WA
    539
    If you want, post your tune and Ill verify you've removed all the TM.
    ~Erik~
    May 2020
    2
    Hello, everyone. I need your help. It is necessary to speed up the throttle operation. P10. Trailblazer L6 2005. I didn't work with the program before. What needs to be changed in Torque Management? what numbers should be?
    May 2006
    Seattle, WA
    539
    Replied to your PM. Post your tune here and I can make suggestions.
    ~Erik~
