Results 1 to 2 of 2
Thread: VE Tuning...No PE???
    Tuner tonyvette's Avatar
    Oct 2013
    Macon, GA
    52
    I was attempting to get my VE dialed in a couple days ago using Bluecat's tool. I disabled MAF and went for a drive to log data. I soon noticed that there was no PE kicking in. Do I have to adjust VE rich in the higher kPa range when SD tuning or do I have something set wrong?
    I already overwrote my tune where MAF was disabled, but here's my log file. PE works fine with MAF enabled. Look at area beginning around frame 19,000.
    7-14 scan no maf.hpl
    2012 Colorado 5.3
    Magnum 70mm turbo
    RevMax 2800 stall converter
    DevilsOwn meth
    13,565
    This is a good guide, likely clear up some questions.
    http://michigansnowmobiler.com/hptun...ons%20rev2.pdf
