Is my Com Lambda and Lamb Err set up correctly?
Please take a look. I am new to working with lambda and set up my config with commanded and error with histograms but not sue I understand the readings. Are they set up properly?
I show 1.1xxx - 1.2x, shouldn't it be closer to 1.0? My error is showing values of -40's, what do those numbers represent? It should be % error but why are the numbers so high? Are they doubled due to scaling?
This is a 2006 C6 LS2 with 2 bar OS 12605732
Thanks for looking
E38_E67_08sd NGK WB Lambda.cfg
LAMBDA 1.hpl
Can't look at the config on my phone obviously but maybe this link will help. Possibly you have seen it before but if not it should answer some questions or guide you some atleast.
http://m.performancetrucks.net/forum...d.php?t=524099
