Results 1 to 4 of 4
Thread: Lost1 Why is my MAP reading so high
    All of a sudden my MAP reading is very high. It is showing crazy numbers like 155 at idle and then 300's driving around and I can't figure out why. Car is running normal and my boost gauge works fine so which tells m its setting. It is a 3 BAR GM MAP Sensor.
    MAP JACKED.hpl
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,275
    reading 53kpa at idle, looks fine to me.
    the table shows correctly but on the chart it reads wrong and it doesn't matter what config I use.
    Has this ever happened to anyone before? It does the same with boost, I created the Boost PID using the instructions under Help and it would read 33 at idle.
