Results 1 to 9 of 9
Thread: cant get my mpvi to datalog
    Feb 2013
    32
    ive been able to go in the editor and mod the tune and download to the car. I can also connect the lab top to the car and watch the gauges and the histogram. but I cant get the mpvi to datalog. its a 01 Camaro m6. I just got the programmer about 2 weeks ago.
    Advanced Tuner CatnipG5Bandit's Avatar
    Apr 2013
    El Paso, TX
    297
    Press spacebar to begin recording. Once finished, press spacebar to stop. To save it, Click on the "scan" tab in the upper left and click "save as" then save it under whatever name you want. To see the values in the histograms afterwards, right click and select, "load all data"
    Feb 2013
    32
    Should it record on a 01 camaro with the comp disconnected? I don't have any auxiliary channels. No wb yet haven't installed it. If i press and hold record on the movie I get the red error light.
    Nov 2002
    Central Florida
    2,503
    Are you talking about standalong logging, or when connected
    to the laptop?
    Feb 2013
    32
    I think I got it had the configuration wrong. It works off the labtop now
    Aug 2014
    2
    I'm having the same issue, what is it you had to change?
    Feb 2013
    32
    I had to write the configuration to the mpvi. Then it works. Also had to go into he scanner and add in the maf and map so I could see the sensors haven't went in to add the histograms. But I need too. Adding a wideband to it so I'm Gona do all that then
    Tuner ari666's Avatar
    Oct 2011
    australia
    61
    same issue here too.
    although ive followed all the steps in the "how to' vid. mine just refuses to scan
    1966 impala. L29 454. 0411 pcm. 2.5" twin system. comp cams XR282HR. ported heads. 1.75 rollers. 60lb deka injectors. bosch 044 pump. standard intake (cos' looks cool in a 66')
    Oct 2011
    australia
    61
    found the fix.
    have to search for your .os file (type *.os into the search) in your laptop and delete it. then when you reconnect the car it rescans all available parameters, you reload your config to mvpipro datalogging.
    worked for me anyway
