My LTFT are dialed in very close to 0 with no KR. I started to work on MAF table at WOT but have a quick question. I've disabled COT and LTFT set my PE and did a test run from 2nd. Of course it was off by close to 10%. I'm using an AFR error histogram. Do I just copy the entire row of data (from 0 to 15,000Hz) and paste special over the same cells in the MAF Calibration table? This is the same table I used on my LTFT's. I'm worried that the lower Hz data here will screw with my LTFT's when I enable them. Or do I start my copy in say the 5150 Hz cell and copy and paste only after that?
Also should I be seeing KR at WOT? If I am is my PE set too low or will it correct itself as I bring the MAF table closer to 0?
